KStromberg
Vortech kicked in yo
Hmm, same rwhp pretty much as the T-Bird SC you have that runs high 12s.
Nah, it's been a while since the SC was on a dyno, it's probably closer to 320 now. Look at the MPH.Hmm, same rwhp pretty much as the T-Bird SC you have that runs high 12s.
The loops are when the TC locked. They didn't want to wait around while I adjusted it to lock sooner.I don't understand the loops in the curves?
I think 360 HP at the flywheel may be reaching. The HP loss to the driveline should be static for the most part, not proportional.
I'm just saying whatever the parasitic driveline loss is, it is nearly the same at a modified HP level as it is stock.The loops are when the TC locked. They didn't want to wait around while I adjusted it to lock sooner.
I used a very conservative 15% driveline loss when I came up with that guess. What's your guess and why?
So...But to answer your question, I have found my numbers used to be approximately 17% driveline loss or about 48 HP. I think your flywheel HP would be 350ish which is why I said 360 may be a bit much.
Regardless, it is obviously significantly more than stock and certainly an admirable achievement.
The powerband would move up the RPM scale. How far up would depend upon how much the runners were shortened.I'd be curious what would happen if you shorten the runners on the intake also.
Is this even possible?The powerband would move up the RPM scale. How far up would depend upon how much the runners were shortened.
Would I say it if it wasn't?Is this even possible?
The 303.12 RWHP isn't the least bit affected by any "torque converter flashing". The TC was locked way before the HP peak.Nice numbers, it looks like they are somewhat inflated however due to the torque converter flashing. Impressive nonetheless.
I was more wondering if it is possible to shorten your cobra manifold runners. I guess that would mean you would have to switch to yet another intake manifold if it was so desired.Would I say it if it wasn't?
Look at these dyno runs from my Cobra from 10 years ago.
Why couldn't he just modify the one he has on the car nowI was more wondering if it is possible to shorten your cobra manifold runners. I guess that woul dmean you would have to switch to yet another intake manifold if it was so desired.
No need to switch, but it's a huge PITA to do. The runners are epoxied in, so the epoxy bond needs to be broken, the runners removed and shortened, and then epoxied back into place.I was more wondering if it is possible to shorten your cobra manifold runners. I guess that would mean you would have to switch to yet another intake manifold if it was so desired.
Who knows?I guess the real question would be, with all that hassle, besides shifting the curve higher, would it gain you any quantifiable horsepower that would net you a better et.
Those Cobra cams you have in stock could likely compliment this idea.Who knows?
I picked up 15+ HP (above 6K) and ~3 tenths in my Cobra back in the day, but I'm not sure what the results would be with the Mark VIII intake cams, less gear and an automatic transmission.
Probably wouldn't hurt, though.
