DLF
ENGINE: (From his web page)
Kooks 304 Stainless Steel Headers, High FlowMetallic Cats
2 1/2" Mandrel Bent 304 Stainless Steel Exhaustw/MagnaFlow Mufflers
Canton Racing Products Oil Filter Adapter, Relocated OilFilter
Solid Motor, Transmission and Crossmember Mounts
SuperChips Custom Tuning Pro Racer Package
SVT Focus "Green Top" Fuel Pump
Cobra Intake Manifold
Accufab Oval Throttle Body
FRPP IMRC Deletes30 lb. Bosch Fuel Injectors
Canton 13-784A Aluminum Oil Pan
Canton 20-939 Windage Tray
March 1175 SFI U/D Pulley Set
DRIVELINE:
BOC Stage I 10" 3,600 RPM StallTorque Converter
"J-Mod" 4R70W Separator Plate
BOC Tailshaft Forced Lube Mod, LPW Transmission Pan
B&M 70297 SuperCooler Transmission Cooler w/Fan
DynoTech 4" Aluminum Driveshaft
Eaton True-Trac Differential, FRPP 4.10 gears
99 Cobra Aluminum Pumpkin, LPW Differential Cover
Energy Suspension Differential Bushings
SUSPENSION:
98 SVT Cobra Wheels (17x8 Front), M-1007-M179Wheels (17x9 Rear)
245/45ZR17 (F) and 275/40ZR-17 (R) Firestone Firehawk Wide Oval Tires
99 Cobra Front & Rear Hubs, F&R Koni SportShocks
Stainless Steel Rear Upper Shock Mount, EnergySuspension Bushings
Brembo Cobra "R" 4 Piston Front Calipers, Cobra 13" Front and11.65" Rear Rotors
Paragon Performance Custom Stainless Steel/Kevlar Brake Lines
Stainless Steel Speed Bleeders
ADDCO 1 1/4" F/R Anti Sway Bars, Energy Suspension Bushings
MODULEVIII Air Ride Suspension Controller
Stainless Steel Forward Strut Rod Sleeves
Delrin IRS Bushings
OTHER:
Flaming River Stainless Steel Steering Coupler
Energy Suspension Steering Rack Bushings
FRPP M-3601-B Steering Wheel
"Glitch" Neon Inverter
PLANNED:
Cobra Intake Cams (in stock)
62,833 miles. Mostly garage kept. Maybe a set of the wheels on the tire rack will fit, and can be included. Pretty sure the cams are on the garage shelf as mentioned above I also have a spread sheet of the Lincoln's times (in case he didn't post - HA) I have the court papers settled that permits me to sell his car. Kindly make an offer if interested. Would prefer local pick up but willing to drive a state radius to meet if need be. Donna Fraleigh
DRIVELINE:
SUSPENSION:
Delrin IRS Bushings
OTHER:
PLANNED:
