BlackIceLSC
I sort of feel the same. Not discrediting you or your car but those are more like flywheel horsepower on a 20 year old engine, not RWHP...I've seen some slight increases with a set of pulleys, but those must be made of wizard magic.I'd like to see the car run on a different dyno, I'm having a hard time believing those numbers.
what track do you race at?
if you scale the car and make a run, it will pretty much give us/you the "real world" numbers....of course, DA, barometer, water grains, etc will factor.
http://www.wallaceracing.com/et-hp-mph.php
and the flywheel to rear wheel calculator
http://www.mk5cortinaestate.co.uk/calculator4.php
Based on the first calculator, your 260.5 hp at the rear wheels should be about 325 at the crank....that's a 45 hp gain from pulleys? hmmmm
if that is the case, you should run about a mid 13.50 @ 101-ish mph if the car weighs about 3850 + 200 lbs driver
