headlight issues.
newf
My auto lights and low beam lights won't work I checked the bulbs and they are fine. I replaced the switch and still have the same issue. Any ideas on what the issue may be?? It started when I hit a bad run in the road. Smashed my running lights off. So disconnected them and removed them.
Fuses would certainly be the first place I'd look. I'm assuming these were aftermarket DRL's, wired into the running light circuit? I'd guess that they shorted something out when they broke. Although since these cars have autolamp, there must be some sort of "lighting control module" in there somewhere as well, which probably has some semi-delicate electronics within it.. I can't say I've ever had to troubleshoot that system myself before, but that'd be my #2 guess.
newf
No i check all fuses. Replace the h/l relay. Checked the bulbs. The fog lights were aftermarket yes. I just broke the glass on them. The bulbs on them were fine also.
