Lownslowlsc
It's annoying. I really gotta put in some strength when selecting which gear I want it in. It's been like this since I bought it. I've seen some random g2 m8 vid's that make me think it's a somewhat common/normal problem.
I'm no ussy but come on.. The other 2 car's I'm used to driving go through p r n d 2 1 like butta.
So is this the "tube" I need to spray into? You can't see it but there is an opening.
Can I lube it too much? I want to get in there pretty good, just want to make sure nothing inside said tube can be effected by it.
Should I use:
Wd-40
Or I have some Walmart brand(SuperTech) "lubricant" as it say's..I think it's similiar to wd-40.
I have white lithium grease but I doubt it would do much as it doesn't "flow".
Should I use:
Wd-40
