ok, So I got impatient and did it tonight anyways because I knew it was going to keep me from sleeping
Anyways I got quite a few codes, looked them up and I'm not sure if they make sense because a couple of the codes come up with the same issue. So here are my Codes and what I found. I'm not sure what some of them mean but I am assuming a few of them are telling me I need to replace sensors.
17 - Reference Voltage Problem (Have no Idea what that could mean specifically)
31 - Left Front Wheel Sensor (Assuming that means it needs to be replaced?)
32 - Right Front Wheel Sensor (Assuming this needs to be replaced as well?)
35 - Left Front Wheel Sensor Erratic Output (?)
63 - Pump Motor Speed Sensor (?)
75 - Left Front Wheel Sensor Erratic Output (?)
One of the things that makes me wonder if I have the right meanings for the numbers is that 35 and 75 say the same thing... Thank you again for all your help here, I actually feel like I'm starting to get somewhere now with the help
