ok, i pulled the hose off the line, no fluid. moved up to the pressure switch on the drivers rear, no fluid. went up to the front, and cracked every line off the manifold in front of the battery, fluid out of all. went back down into the inner fenderwell, cracked the top restrictor, fluid all over, cracked the bottom, not a drop under pressure, but if i let it sit for a minute and watch it gets just a touch out of it under gravity, not enough to drip but just that i can see it. theres no other connections between those restrictors and the abs manifold? i gotta pull the front bumper off it to get at the abs dont i?
